with turbo h22 accord ecu
Old Jul 7, 2007 | 09:17 AM
porky's Avatar
Default with turbo h22 accord ecu
im having trouble with getting the right ecu for my car i have a 94 accord with a 95 h22 obd1 engine and turbonetics stage two kit and i have heard some good things about the chrom setup and wanted to know what ecu to put it on the other upgrades i have are skunkII intake and 68mm throttlebody exaust and some msd extras
Old Jul 7, 2007 | 12:31 PM
Loco-B's Avatar
Default Re: with turbo h22 accord ecu (porky)
i think either the p14 or the p28.
can someone else verify?
That way, if you do a chipped ecu, you wont have to run an EMS like chrom.
Old Jul 7, 2007 | 01:07 PM
raceACCORDingly's Avatar
p28 or p72 with h22 bin
check out http://phearable.net/ or http://xenocron.com/
Old Jul 7, 2007 | 08:16 PM
flight50's Avatar
Default Re: (raceACCORDingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">p28 or p72 with h22 bin
check out http://phearable.net/ or http://xenocron.com/</TD></TR></TABLE>
the two above are your best options. if you want to use the knock and the secondaries, use the p72. as far a chrome, check with your local tuner and run the program that he is either familiar with, or best at. there is hondata, neptune and uberdata out there. unless you wanna spend 700+ then you have the big boy stand alones. if your doing the tune yourself chrome would be okay, but i would recommend you not, considering you don't know which ecu to use. not knocking, i am just saying. let a pro do your tune before you screw your motor.
Old Jul 7, 2007 | 09:10 PM
porky's Avatar
Default Re: (flight50)
thanks 72 sounds good for me and don't worry i got a friend with a dyno and im gonna let him do all the tweaking
night_mare92
Oct 8, 2010 06:34 PM
Bmxlambis
Apr 4, 2009 07:19 AM
mmk21
10
Feb 15, 2008 06:14 AM
rocketfuelcerx
Apr 10, 2005 02:23 AM
xavier
Dec 2, 2001 10:26 AM
