eg pros come in: bumper gap
also you could be missing the bumper support bracket that holds the corners of the bumper along ( its that metal bar that seems to do nothing in front of the headlights when you remove the bumper)
i have no gap?
i have no gap?
no no no, there is a metal slot directly under the headlight where a portion of the bumper slides into and seats perfectly.
from the picture it looks like you are directly beneath the slot that i'm talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">also you could be missing the bumper support bracket that holds the corners of the bumper along ( its that metal bar that seems to do nothing in front of the headlights when you remove the bumper)
i have no gap? </TD></TR></TABLE>
its suppossed to hold the bumper up and allow the bumper to slide back all the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJ0LNIR »</TD></TR><TR><TD CLASS="quote">If we wanted to read that we can go to paint/body section, where it's posted.</TD></TR></TABLE>
Fukk off, if it was so redundant you should have provided some insight in atleast one of them. I posted two threads bc maybe someone who has the answer will never look in that forum.
As for people who actually want to help, I do not have the bumper support in at all. Therefore the mentioned brackets are also not in. Im going to put the beam in and see what happens. Also I was given an idea in my other thread about using different hardware. I will try that as well. If the project fails I will be back in here, okay? Thanks guys.
CALC!_JUST_du_IT!
Aug 26, 2008 10:36 AM
oem_CD5
Jul 13, 2006 12:00 PM
Keith P
12
Apr 25, 2005 04:17 PM
