help !! alarm : car wont start.
so today when i try to start my car..
when i press the unlock button on my remote .. there is no sound.
the light in the middle on my dash, flash 3 times and stop. and continue doing the same thing.
i got my alarm a while ago. .. at least 3-4 yrs ago.
when i try to start my car.. everything just flash on my dash, light, gauges.
and it wont let me start my car.
i can only lock my car.. when i press the button again.. it wont unlock.
please help !! i dun know nothing about alarm. thanks in advance!!!
please help asap !! i cant even drive my car anywhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aandrewcc »</TD></TR><TR><TD CLASS="quote">when i try to start my car.. everything just flash on my dash, light, gauges.
and it wont let me start my car. </TD></TR></TABLE>
What do you mean they flash?
Does the starter crank??
no it doesnt crank..
it feels like the kill switch (ignition kill) is on.
they flash .. like my alarm went on.. but without sound.
Have you tried replacing the battery in the transmitter?
Put the alarm in valet mode and take it back to the shop that installed it. Reputable shops all have a lifetime warranty on the install. And DEI has a lifetime warranty on their product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">When you press the unlock button, does the LED on the transmitter light up?
When i press the unlock button the light just keep on flashing..
when im not pressing anything the light also continuously flashing.
and
"When you press the unlock button, does the LED on the transmitter light up?"
i dont think so.
thanks !
and
i dont think so.
thanks !
i dont think the battery is out.
because the day before my alarm went on silence mode.
and i was messing around, trying to get the sound back on. but then we became like this.
Can anyone help ??
i think i am in some type of mode..
i was thinking of taking the alarm brain out.. so at least i can drive my car..
the LED flash 3 times.. and stop for 4 second.. and flash again.
my LED never do anything like this before.. so im sure i am in some type of mode.
please help !!!
please help !!!
610T is not a DEI alarm model number, maybe the remotes model number.
You will need to find alarm brain to get a model number.
Have you tried the manual override, turn ign. on and press valet/program switch/button.
Also try a reboot, disconnect batt. neg.(-) turn ign. switch on, [to run] and reconnect batt. neg.(-).
If the dash/park lights are flashing it indicates the alarm is triggered.
The LEDs flash-back , [3 times] is the the indication of what is triggering the alarm, but need to have a model number to know what 3 flashes is.
Although most if not all DEI alarms have a programmable and one-time chirp defeat, [no siren chirp when arming and disarming] I do not know of any, [entry level] that have a "silent" alarming mode.
94
94
is these the valet button and stuff ??
i have three button, i am not sure which one to press. i try all of them ,, but nothing happens.
i have tried these :
all my light, dash just started flashing...
Not sure why you have 3 buttons, but that is what the DEI valet/program button looks like, one of them may be for "blackjax" an anti-car jacking feature some DEI alarms have, the 3rd one I don't know.
Fallow the wires from the buttons, the valet/program button plugs into the alarm brain, the problem is that deff. DEI alarms have diff. manual override procedures, so a model number is needed, it would also allow you to unplug the unit and at least get the car going.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> it would also allow you to unplug the unit and at least get the car going.
94</TD></TR></TABLE>
To get it going to return to the original installer for them to fix the problem...
94</TD></TR></TABLE>To get it going to return to the original installer for them to fix the problem...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aandrewcc »</TD></TR><TR><TD CLASS="quote">^^ i bought the car with the alarm. </TD></TR></TABLE>
Then you should be more specific when you type things, because that's not what you said in your first post...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aandrewcc »</TD></TR><TR><TD CLASS="quote">i got my alarm a while ago. .. at least 3-4 yrs ago.</TD></TR></TABLE>
Did you do what FCM said yet??
yeah, but i couldnt find the brain of the alarm.. there a lot of things in the way..
i might need to take my dash apart for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aandrewcc »</TD></TR><TR><TD CLASS="quote">yeah, but i couldnt find the brain of the alarm.. there a lot of things in the way..
i might need to take my dash apart for it. </TD></TR></TABLE>
Well, it's pretty obvious from your posts that you're only interested in a quick fix and you're not willing to do any legwork...
Come back only when you've gotten the model number off the brain and stop wasting our time.
No, i am going to take the dash apart. i just wanna see can i fix it the easier way before i take the dash apart.
how an alarm brain looks like ???
i just took some stuff apart.
i see this black square looking box , says DEI on it.. will that be the brain ?
I can get the car to running now by disconnecting the brain fuse.
but i dont know how to reset it or anything like that.
i tried to search on google, but cant find anything to fix my problem.
please help thanks !
