help on my b20 swap
I have a 95 civic coupe and i have the motor and motor mounts and siftlinkage .what else do i need to do the swap. im going to do a b20/vtec and want to know what would i be running??.. does anyone have picutures of someone that did that swap and what pistons should i throw in the b20 ..thanks...
You'll need some preparatory skills. Like researching what you need BEFORE you start buying parts.
This has been covered a lot.
» Search Results
Your search for b20 returned 797 results.
You'll need the ecu. I Hope you have a tranny or plan on getting one, I didn't see you list it.
https://honda-tech.com/zerothread?id=979961
Go to that thread.
» Search Results
Go to that thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">You'll need some preparatory skills. Like researching what you need BEFORE you start buying parts.
» Search Results
Go to that thread.</TD></TR></TABLE>
Hey, I DIDN'T search - but I was j/w - Usually people use the LS ECUs with the B20 setup. Though didn't the CRV only come in auto? So if you wanted a manual B20 w/ a B20 ECU, is there anything you can do besides chip an OBD-I ECU and run it w/ a basemap for the B20 but set to manual?
» Search Results
yudruln2402
Nov 3, 2004 04:20 PM
