blown headgasket?
Old Jul 6, 2007 | 12:19 PM
Peter Brady onlyonweekndz's Avatar
Default blown headgasket?
my accord has been overheating and you can see bubbling in the coolant resivoir. i just did a cold compression test that was 210, 180, 200, 205, #3 being the 180. do u guys think this is a headgasket problem? i dont see what else it could be..already searched, just makin sure..any input would be appreciated...
Old Jul 6, 2007 | 12:24 PM
SuShiBoiiii's Avatar
Default Re: blown headgasket? (Peter Brady onlyonweekndz)
thermostat? bad coolant? look into those..headgasket symptoms are like leaking oil...and werid smoke out the exhuast i think correct me if im wrong
Old Jul 6, 2007 | 01:32 PM
ujhonda's Avatar
Default Re: blown headgasket? (SuShiBoiiii)
overheating cause blow head gasket -
but for now check your T-Stat, coolant, etc...make sure your water pump is working. If you have air pockets in your cooling system -- yep it will cause over heat and blow your head gasket...even crack your Head or Block....
I had this nightmare - end up replacing the engine.
Hoopdie91
Apr 3, 2016 06:15 AM
BigJerm333
12
Aug 5, 2014 08:01 AM
turbols99
Feb 5, 2007 07:28 PM
junglistgsr
Apr 1, 2003 08:13 AM
veejay
Jun 30, 2001 09:02 AM
