!!!!!SPRINGS & CAMBER KITS!!!!!
Had a quick question about lowering your car. If you drop your car on springs, do you still need to get a camber kit setup, or is that only if you get coilovers? I know your wheels will tilt without a camber kit, but was just wondering if you needed a camber kit either way.
gettin camber kit depends on how much you're dropped... i'm dropped like 2.5-3 inches on coilovers and i only have one in the rear front is fine... it's negative camber but it's fine
as for your other question it doesn't matter if its springs or coilovers just depends on the drop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">dont need camber kit just get allignment and get the toe set to 0 and you'll be fine </TD></TR></TABLE>
Correct me if I'm wrong, but I think that the older Hondas (like this specific forum) aren't equipped from the factory with alignment correction.
I'd recommend the Skunk2 camber kits (you can take the cheap route for the rear and do the washer trick), and then get an alignment AND your toe corrected.
Do your tires a favor.
This is the '92-'00 forum, so I'm assuming his is in that range.
I know that my '94 Civic DX didn't come from the factory with alignment correction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 »</TD></TR><TR><TD CLASS="quote">
I know that my '94 Civic DX didn't come from the factory with alignment correction.</TD></TR></TABLE>
Most ALL cars come with factory toe adjustment correction.
It's camber correction that cars don't come with.
Camber kit Shmamber kit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic »</TD></TR><TR><TD CLASS="quote">dont need camber kit just get allignment and get the toe set to 0 and you'll be fine</TD></TR></TABLE>
Friend has that and hes almost tucking rims, for 2 years now. Let some tire PSI out too, he has NO wear whatsoever
No need for any "camber" kit, lol
looks like you been corrected
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">Most ALL cars come with factory toe adjustment correction.
Camber kit Shmamber kit. </TD></TR></TABLE>
I may be digging myself a hole, but oh well.
Camber is the tilt of the tire inwards or outwards correct? Whenever you lower a car, the tires tilt inwards, correct?
I know when I first had my car lowered on Eibach Sportlines the negative camber was ridiculous and I could see the wear on my tires from driving it ONE DAY without it being aligned. When I put my drop kit on, I also put some new tie rod ends on and got both the camber corrected AND the tow adjusted to 0 degrees.
Since then I haven't seen any abnormal tire wear and my tires are perfectly vertical.
That's my personal experience, but I know that both the camber and the tow being out of whack isn't good for tires.
But I know the camber kits did something
EDIT: ek forever guy, I meant to add in that most cars don't come with camber adjustment from the factory, but they do come with tow adjustment, my bad
It might be just me, but looking at that, it gives the appearance that camber would be more detrimental as opposed to tow (although neither are "good").
You're talking about only a small section of your tires coming into REAL contact with the road...get where I'm coming from?
You can probably get by without a camber kit, but I know that I can't afford tires to that extreme.
I ran negative camber on my front/rear wheels for a year and a half on my first car, with no uneven wear at all.
The SMALLEST amount of toe will eat tires like there's no tomorrow.
Many people run negative camber for the boost in handling capabilities.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 »</TD></TR><TR><TD CLASS="quote">It might be just me, but looking at that, it gives the appearance that camber would be more detrimental as opposed to tow (although neither are "good").
You can probably get by without a camber kit, but I know that I can't afford tires to that extreme.</TD></TR></TABLE>
who needs tires anyway ride em on the rimz
get your toe set to 0 and let some psi out of your tires so they make full contact...not to mention heds getting an eibach pro kit and that barely even constitutes a drop in the first place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">I ran negative camber on my front/rear wheels for a year and a half on my first car, with no uneven wear at all.
Many people run negative camber for the boost in handling capabilities. </TD></TR></TABLE>
From what I remember, my toe was WAY out of whack (4 degrees or something along that line), which probably had a lot to do with the tire wear in that one day.
But, I still feel comfortable knowing that I don't have negative camber...it may not be a necessity, but I went ahead and invested in it.
liquidoblivion
Apr 29, 2004 12:32 PM
SiRocket02
Dec 28, 2003 09:06 AM
