Loose Shifter
Old Jul 5, 2007 | 07:09 PM
tei344's Avatar
Default Loose Shifter
The shifter in my 1993 civic D15b7 is pretty loose left to right when I'm in gear. Doesn't pop kick out of gears and it's tight front to back. Any simple fixes before I get my short shifter?
Old Jul 5, 2007 | 07:48 PM
bmoua's Avatar
Default Re: Loose Shifter (tei344)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tei344 &raquo;</TD></TR><TR><TD CLASS="quote">The shifter in my 1993 civic D15b7 is pretty loose left to right when I'm in gear. Doesn't pop kick out of gears and it's tight front to back. Any simple fixes before I get my short shifter?</TD></TR></TABLE>
energy bushings will help you out bro...
Old Jul 5, 2007 | 07:49 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Loose Shifter (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">
energy bushings will help you out bro...</TD></TR></TABLE>
Not for side to side while In gear.
Take a look at your Shift linkage "bitch" pin.
Old Jul 5, 2007 | 07:52 PM
bmoua's Avatar
Default Re: Loose Shifter (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
Take a look at your Shift linkage "bitch" pin.</TD></TR></TABLE>
true, haha forgot about that.
Old Jul 5, 2007 | 08:00 PM
Ek Forever y0!
true, haha forgot about that. </TD></TR></TABLE>
Though while he's down there, it IS a nice upgrade.
Old Jul 13, 2007 | 08:18 PM
tei344's Avatar
Default Re: (solbrothers)
what do you me while i'm down there. I have a lift. It's all up for me. but the problem is i'm not quite sure what I'm looking for. I get my new short shifter on monday from pace setter and My energy suspention bushings should come in close to then, but what's the bitch pin and where do I get a replacement.
-TEI-
Old Jul 13, 2007 | 09:44 PM
nicko360's Avatar
* B A N N E D *
Default Re: (tei344)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tei344 &raquo;</TD></TR><TR><TD CLASS="quote">what do you me while i'm down there. I have a lift. It's all up for me. but the problem is i'm not quite sure what I'm looking for. I get my new short shifter on monday from pace setter and My energy suspention bushings should come in close to then, but what's the bitch pin and where do I get a replacement.
-TEI-</TD></TR></TABLE>
its the pin that holds the linkage to the tranny, i think its called a gator pin or something. sometimes when people loose them they try to put a screw threw there and is ***** it up
Old Jul 18, 2007 | 02:25 PM
tei344's Avatar
Default Re: (nicko360)
Just to keep people updated... I got a Pace Setter short throw, and I'm waiting for my Energy Suspension bushings to come in the mail. I still haven't worried about the Bitch pin, but I'll probably just check it out while i'm putting all my new fun stuff in.
Old Jul 18, 2007 | 02:28 PM
Sr420Det's Avatar
Never heard people call it a bitch pin, but damn thats an appropiate name for it. Its a cinch to get out if you have the right tool but for some reason Ive never been able to put it back in all the way (until I take it back out).
Old Jul 18, 2007 | 02:38 PM
gsrturbo-ek's Avatar
Default Re: (Sr420Det)
had the same problem and it wasnt the shift linkage it was acually the shifter it sell the part that bolt into the shift linkag the rubber o-rings got fucked up and coused it to have play
Old Jul 18, 2007 | 07:04 PM
rdwaldo's Avatar
Default Re: (gsrturbo-ek)
make sure the bolt that connects the shift linkage to the shifter is tight. If someone else did it, they may not have adjusted it correctly since you can tighten it to your preference
Old Jul 18, 2007 | 10:36 PM
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrturbo-ek &raquo;</TD></TR><TR><TD CLASS="quote">had the same problem and it wasnt the shift linkage it was acually the shifter it sell the part that bolt into the shift linkag the rubber o-rings got fucked up and coused it to have play</TD></TR></TABLE>
I concur.
CountryHonda
12
May 11, 2008 08:55 PM
realis9
Jan 19, 2006 05:30 AM
Kyles ej1
14
Oct 2, 2005 09:27 PM
hotdoggies
10
Mar 1, 2005 04:35 PM
djblackcell
Jun 1, 2004 05:02 PM
