headlight bracing cracked...
A while ago the bracing that holds one of my headlights in its socket cracked (probably due to heat/cold expansion/contraction). The headlight still works, but it wont sit in its place... I tried superglue but there is no way I can apply clamping pressure with the headlight put in place... I'd rather not shell out 300+ when the light works fine.
Was hoping someone had an idea of how to fix?
bump...
thinking now about going to a junk yard and buying a new light to replace the entire apparatus...
and also to clarify, it is not the headlight but the turn signal...
