d16a6 pistons and rods in d16y7 bloack??? need this info asap plz
Old Jul 5, 2007 | 12:18 PM
dcsports's Avatar
Default d16a6 pistons and rods in d16y7 bloack??? need this info asap plz
can i use d16a6 pistons and rods on a d16y7 block with no problems need a answer asap cause im bout to order honda rod bearings for this project and i cant return them
Old Jul 5, 2007 | 02:48 PM
Aquafina's Avatar
Default Re: d16a6 pistons and rods in d16y7 bloack??? need this info asap plz (dcsports)
Yes. Check your clearances before you order the bearings though.
Also check P-V. A6 pistons have smaller valve reliefs.
Old Jul 5, 2007 | 07:19 PM
dcsports's Avatar
Default Re: d16a6 pistons and rods in d16y7 bloack??? need this info asap plz (Aquafina)
thanks for the reply i orderd the bearings straight from honda also wat do u mean by p-v??? im using a d16y8 head by the way
Old Jul 7, 2007 | 12:17 AM
Aquafina's Avatar
piston to valve
iwanttogofast
Dec 26, 2008 04:18 PM
dcsports
Jul 5, 2007 07:46 PM
the g2 teg
Aug 21, 2004 07:22 PM
