ZC dual cam in eg
ok i treid searching didn't really come up with much. i kno all the single cam trans will bolt on to this motor. what i do need to kno is do i have to change any of my motor mounts in my car now to swap in the ZC engine into my EG 4door? the reason im doing this is i have 205k on the car the old motor smokes at high rpm and the person who had the car be4 me never changed the oil. and i really do not trust it. and i can get my hands on this ZC engine cheaper then going to a yard and pulling another single cam. one more thing can i use my OBD1 injectors in the fuel rail on the OBD0 ZC motor or can i swap the fuel rails? thanx guys
to use the OBD-0 DOHC ZC in a EG you need:
-D16z6 driver side mount/bracket
-OBD-1 injectors
-OBD-1 Special Distributor(TD XX?)
check out
http://www.thezcr.com
-OBD-1 injectors
check out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.R »</TD></TR><TR><TD CLASS="quote">to use the OBD-0 DOHC ZC in a EG you need:
-OBD-1 injectors
check out
http://www.thezcr.com</TD></TR></TABLE>
ok so i need a head mount from a Si (d16z6), i have injectors, now the distributor is confusing. wat do you meen by special? ill look around some more on that zc website ,thanx alot
-OBD-1 injectors
check out
95civ
Oct 20, 2005 06:06 AM
