Bad fuses, broken bulb or bad connection??
Old Jul 5, 2007 | 08:17 AM
VTECth1s's Avatar
Default Bad fuses, broken bulb or bad connection??
1- The passenger side headlight on low beam does not turn on. But only when it's on high beam. I presume it's a bad bulb and just needs replacement?
2- The passenger side jdm foglight does not turn on at all, driver's side is perfectly fine. Bad fuse? bad bulb? bad connection?
Cliff: Not fond or savvy on electrical wirings. And the car is an EH2 (eg6) hatchback.
Old Jul 5, 2007 | 08:52 AM
ek4_b16a's Avatar
Default Re: Bad fuses, broken bulb or bad connection?? (VTECth1s)
check the fuse under the driver side...there is a fuse for low beams and high beams...
VTECth1s's Avatar
Default Re: Bad fuses, broken bulb or bad connection?? (ek4_b16a)
Ill check that for sure, what about the passenger fog light any clue?
peter.s
Apr 9, 2018 05:27 PM
Haulinbass08
Jan 22, 2015 05:13 AM
not-a-stang
Apr 9, 2008 07:50 AM
95lscivic
Jan 14, 2008 08:31 AM
VTECth1s
Audio / Security / Video
Jul 7, 2007 08:37 AM
