car wont start without a jump....
Old Jul 4, 2007 | 05:54 PM
si_motor_spt's Avatar
Default car wont start without a jump....
Hi, well im new to this but i just wanted some help on my 2000 honda civic Ex. it all started when i tried to change my throttlebody, i started the car and my check engine light came on and was running rich, so i changed my MAP sensor and the light went away but it still remained running rich.. and the car wouldnt start unless i jumped it so i figured it was the alternator so i changed that and same problem still exists..(running rich and not starting unless i got a jump) can i please get some help... Thanks
Old Jul 4, 2007 | 05:58 PM
HackeN's Avatar
Default Re: car wont start without a jump.... (si_motor_spt)
check battery terminal conenctions for a tight/clean connection?
Old Jul 4, 2007 | 05:59 PM
Default Re: car wont start without a jump.... (HackeN)
i checked those, sanded everything, checked all grounded wires and everything seem to be ok..
Old Jul 5, 2007 | 01:38 AM
mikeycivic's Avatar
is the battery good???
Old Jul 5, 2007 | 02:08 AM
dylan420's Avatar
starter?
Old Jul 7, 2007 | 11:47 AM
HackeN's Avatar
Default Re: (dylan420)
now if the alternator is good/replaced have you checked the battery voltage once car is running (you got a jump and its running)?
The wire that the alternators charge is comming from, has that been tested that the wire has not been damaged in any way? The charge from the alternator may not be getting back to the battery.
Also bad battery like stated above may be a possibility.
tkda
29
May 5, 2009 02:46 PM
Cole89ef
Mar 6, 2009 03:40 AM
xSXExCIVICx
Jul 12, 2008 05:17 PM
my ride
Jul 21, 2004 10:40 PM
Timmay
Feb 27, 2004 04:01 PM
