Internally balanced or Externally balanced?????
Old Jul 4, 2007 | 04:28 PM
Keeper1343's Avatar
Default Internally balanced or Externally balanced?????
I was wondering which one the honda motors are because i am doing a h22 swap and i want to do the 5 pound flywheel, all underived pulleys...... wouldn't that throw off the balance of the internals??? Unless the motor is externally balanced.
Old Jul 4, 2007 | 04:36 PM
117's Avatar
117
Default Re: Internally balanced or Externally balanced????? (Keeper1343)
It's internally balanced. Adding a balanced crank pulley and/or balanced flywheel is not a problem.
BTW, I've never seen a 5 lb flywheel for the H22.
Old Jul 4, 2007 | 07:10 PM
Hawkze_2.3's Avatar
Yeah, as long as the parts you add are balanced it won't mess anything up.
5lbs sounds way too light to be safe....unless it's titanium or something
Old Jul 4, 2007 | 08:22 PM
Keeper1343's Avatar
Default Re: Internally balanced or Externally balanced????? (Hawkze_2.3)
i believe jun makes one for the h22 I have to make sure.... thanks
Old Jul 5, 2007 | 05:06 AM
117's Avatar
117
JUN does make one, but it's not 5 lbs.
Old Jul 5, 2007 | 05:26 AM
Silver Surfer's Avatar
Default Re: (117)
lowest i've seen is 8lb cromoly
Old Jul 5, 2007 | 06:42 AM
lude98SH's Avatar
Default Re: (Silver Surfer)
The Jun lightweight flywheel is 5.5 kg and the ultra light is 5.2 kg, stock is 8.4 kg. Those specs are off an h22a on Jun's site.
Just four your information 5.2 kg eguals 11.464 lbs and 5.5 kg equals 12.125 lbs.
Also i have known that the h22 engine is internally balanced however if thats the case why do people tell you to balance the bottom end together with flywheel,pp and crank pulley ? Because they technically if the crank,pistons and rods are balanced correctly you could balance the flywheel and crank pulley seperately ?
Modified by lude98SH at 7:58 AM 7/5/2007
Old Jul 5, 2007 | 07:00 AM
117's Avatar
117
The way the bottom end has been balanced on the engines I've done is to first balance the crank. Then install the flywheel and balance the flywheel, then install the pressure plate, and balance the pressure plate. Repeat with the crank pulley (without the flywheel or pressure plate). Then as a final check, you can install the flywheel and pressure plate with the crank pulley and double check the balance.
Old Jul 5, 2007 | 07:08 AM
lude98SH's Avatar
Default Re: (117)
thanks but what doesnt make complete sense to me is why cant everything be balanced seperately ? Shouldnt it work technically ? I unserstand to be safe or something do it together
Old Jul 5, 2007 | 07:23 AM
117's Avatar
117
Most machine shops I've dealt with do not have mandrels small enough to fit Honda flywheels and crank pulleys.
You can't balance the pressure plate without a flywheel, as there's no way to hold it.
Old Jul 5, 2007 | 08:17 AM
NirVTEC's Avatar
Default Re: (lude98SH)
A SuperLight FW will rev up faster but also rev down faster.....
12lb'er FTW!
Old Jul 5, 2007 | 11:29 AM
Keeper1343's Avatar
I just read the jun website and i read it wrong... i thought is was 5 pounds and not KG lol... Easy mistake.. Thanks guys you have been a real help. Can't wait to get my EG H22 on the road with about 2500 into it.
Honderachinaldo
Engine Machining & Assembly
May 14, 2019 09:25 PM
H24Turbo
Jan 26, 2010 07:51 PM
lude98SH
Oct 23, 2006 09:53 PM
Jago
Sep 22, 2003 04:41 AM
Timmayeg
Sep 1, 2002 10:07 PM
