Evans Tuning Shop Sale (RC, MSD, Mfactory, Tial, Omni, Strange, Advanced Design, etc.)
Clearing out some stuff we have laying around the shop.
RC 750cc Saturated Injectors: brand new in the box. 3 sets available. 300.00 shipped.
RC 1000cc Peak and Hold injectors: brand new in the box. 3 sets available. SOLD
Advanced Design/Ground Control drag coilover: Used for a season of racing. In like new condition. Comes with 800lb/in front springs and 1200lb/in rear. These are some of the best shocks on the market. Will fit 92-95 Civic and 94-01 Integra. These were used on the Evans Tuning Power Street EG last season. The shocks alone are over $400.00 each corner. Ground Control kit was additional. Independent rebound and compression adjustment on each shock. Paid close to $2000.00 for the entire combo. Looking to get $1000.00 + shipping.
Manley lightweight I beam H22 rods: brand new in the box. These can be used with either an h22 or h23 crank and are probably one of the best lightweight all motor rods you can get for an h-series. $500.00.
Momo race steering wheel with detachable hub assembly: Can be used on 92-95 Civic, 94-01 Integra. Wheel is in like new condition. $225.00 shipped.
SSR 4-1 b-series street sweeper header: Used for less than 100 miles. No dents or scrapes. In like new condition. Flares from 2.5 to 3 inch under oil pan and has 3" vband TIG welded to exhaust end. $900.00
Evans Tuning b-series all motor long block: 86mm bore x 89mm crank. Crank was balanced and polished. Has CP 86mm 7.7cc X-skirt lightweight all motor pistons (skirts and domes coated by Tbone), Manley lightweight LS rods, Golden Eagle sleeved b18c1 block. ARP headstuds, Honda/GE 86mm headgasket. Headgames race ported (b18c1) head. Ferrea competition plus valvetrain (standard sized valves, springs, retainers, keepers). Skunk2 Pro3 cams, Skunk2 cam gears. Brand new type r oil pump, water pump, timing belt, main seal, tensioner. All brand new OEM bearings. Comes with Fluidampr race pulley, Hondata intake manifold gasket, and brand new type r valve cover. Motor has less than 100 miles on it. There are about 10 passes at the track. Best pass was 11.78 @ 115mph in a 2250lb car. Motor pulls over 300psi on every cylinder with less than 5% leakdown. Motor made 248whp with 169ft/lbs with a 93/c16 mix. Motor will make another 10-15whp if tuned on E85. This is a turn key longblock. Does not come with intake manifold, throttle body, injectors, alternator, distributor, or header. $6000.00 firm picked up. Shipping would be additional and would need to be shipped via truck freight.
Thermal 3" stainless turbo exhaust: Will fit 92-95 Civic, 94-01 Integra. Used for less than 1000 miles. 3" stainless vband flange was TIG welded to exhaust where it meets cat/dp. $450.00 + shipping.
All prices are firm and do not include shipping unless specified. Email andrea@evans-tuning.com with questions or PM me here.
Modified by Andrea at 6:12 PM 7/30/2007
Saturated Honda style injectors. Drop in for b, d, and h series. Can also be used with s2000, NSX, K-series, and any other top feed style fuel rail for Nissans, Toyota, etc. using different spacers and studs.
