Slight Missfire in EXR
Old Jul 4, 2007 | 12:41 PM
RiceFed's Avatar
Default Slight Missfire in EXR
95 EXR Accord, stock everything.
Its experiencing a slight misfire from 2000-3000rpm under light acceleration. As soon as you stomp on it the problem goes away. Changed the wires, rotor, plugs so far. Next up is the entire distributor.
Someone told me that it has something to do with the EGR?? Apparently its a quite common problem on the EXr engines.
Old Jul 5, 2007 | 09:14 AM
dustwalker14's Avatar
Default Re: Slight Missfire in EXR (RiceFed)
sounds like it could be an EGR issue as being as its only happening at light throttle. Well thats assuming it wasn't happening at idle also and it just wasn't mentioned. I haven't messed with EGR in a long time but something makes me think it can be the vacuum diaphragm in the valve or something with the EGR solenoid. Regardless I believe it is the EGR is opening up too much (% on a scan tool).
Tester2k
Aug 22, 2014 05:33 PM
Ju664l0
Jun 17, 2010 04:15 PM
schotz
Engine Management and Tuning
Nov 15, 2009 05:38 AM
mark_is_gay
Sep 4, 2006 08:15 PM
dvsracer915
Apr 30, 2005 11:46 AM
