direct swap
Old Jul 4, 2007 | 10:29 AM
montvillefire22's Avatar
Default direct swap
i lost the engine in my daily driver after 250,000 about time well it fits me well and i love the car so i am putting a new or used engine in it but i have ran in to alot of difficulty finding a d16y8 to put back in it and what i was wondering is if some one might no if they was every other engines that will fit in with out going through buying mounts and extensive wiring mods and maybe the same ecu (if it can be done)
Old Jul 4, 2007 | 10:34 AM
uneek360's Avatar
Default Re: direct swap (montvillefire22)
Located right above listed as :
[FAQ] What swaps are available for my Civic?
https://honda-tech.com/zerothread/878010
Old Jul 4, 2007 | 10:35 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Get an OBD2 B16A. That's a bolt in swap. As long as it's OBD2, it will all plug in as well. Those motors are sold with nessacary mounts, linkages axles, etc. They're all stock parts from a 99-00 Si in your case. Plus, you will effortlessly pass emissions. Good bang for the buck bolt in motor. under $2500 at this point for a FULL swap. Very reliable, great gas mileage, and fun to drive. Awesome trans ratio, same as the ITR. The other OBD2 B series will plug and bolt in as well, but you're usually looking to spend more money unless you get the LS motor. BOOORING.
The OBD2 96-00 D series motors will also bolt/plug in, However, the D16Y8 is a difficult motor to find. The OBD1 D series will bolt in, but will not pass emissions unless you put in your oil pump assembly with the CKP sensor from your D16Y8. You will have to switch injectors, and some plugs. switching the intake manifold would be a good idea. And you will probably want to keep your trans unless you get a D16Z6 with trans.
Old Jul 4, 2007 | 11:34 AM
Default Re: direct swap (B serious)
thank you for the info i live in Maine so no emission for me but thanks for the info
1990hondaHF
Honda Fit
38
Jan 15, 2014 11:15 PM
MEn'MYEK
Jun 1, 2012 11:47 PM
Riveninside
Classic Hondas
Jul 21, 2007 08:17 AM
97civicsedan
Apr 30, 2005 05:54 PM
Addijhaq
Apr 24, 2005 07:27 PM
