15" Spoon SW388 wheels (will it fit?)
Anyone have 15" Spoon SW388 wheels (or 15" Regamaster EVO wheels) that fitted with 4-pot Willwood "Dyno-lite" Calipers?
Currently, I have the Wilwood brakes! But, I'm thinking lighting up the corners with these wheels for the track! My 16" Kosei Senakas are just too heavy. I was wondering if anyone had the wheel and brake set up??? Or any better wheel set up for my brakes? (I would prefer running 15"s! I'm more toward performance than looks!) The offset is 45mm on the Spoons, right?
Help!
[Modified by 850, 9:10 PM 6/7/2002]
Help!
What diameter rotors do you use? 282mm is the maximum size and fits in most (read 99,9%) 15" rims. It also depends on the model of the rim. No fancy looking models with a big centre.
I've noticed that larger calipers , including aftermarket, are not so much wider towards the streetside of the rim (causing fitment problems with high offset) but mostly inwards and the length is different to fit the larger pads.
Not sure about the Wilwood. Are they 4 piston calipers? I know for a fact 300mm AP racing discs and 4 piston AP racing calipers on a civic will fit an offset 38 rim BARELY! (2mm space!)
What offset are you currently running?
Todd00
Nov 15, 2007 10:07 AM
