my inner fender lining came off and fucked up the harness
Old Jul 3, 2007 | 04:43 PM
slowcoupe93
Guest
Posts: n/a
Default my inner fender lining came off and fucked up the harness
now my headlight on the side wont come on at night, is that harness a removable pieace or is it with the mian harness, should i just put heat shink all over the exposed wires, replace the blown fuse to fix the problem?
the damn car is also over heating too
and accident damage im considering selling it lol
its a 97 four door ex
Old Jul 3, 2007 | 05:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: my inner fender lining came off and fucked up the harness (slowcoupe93)
The harness on the side is not part of the main engine harness. It is replaceable; but, probably very expensive through the dealer. You can try to pick up the harness from a salvage yard or repair the exposed wire (e.g., solder, butt connectors, heat shrink tubing, or electrical tape, etc.). If you do repair it, make sure the connections and insulation is very good, to prevent shorts, etc. If you replace it, you may want to mark both ends of the various harness connections with tape and writing or something, so that it gives you a reference to compare the old and new harness for re-connection.
The overheating may be unrelated to side harness.
EJ8CIVIC
Sep 2, 2015 03:59 AM
imadigitalgod
Audio / Security / Video
Mar 6, 2009 09:25 PM
