launching on m/t with skunk2 ecu
what are you launching at with m/t slicks and a p28 skunk2 ecu? i have a acura type R, and like to know what you guys are doing and what kind of numbers you guys are getting so i know what i should be getting. how much air do you have in your m/t slicks?
fwhat size rim and slick. come off at 6-6500 rpm. run about 11-12 psi in those slicks. i assume you are using that 15 inch slick with a small sidewall.
i'm using the 22/8/15 m/t. with the skunk2 ecu my vtec kicks in at 5300 instead of 5700, which is stock. i tried 5500rpm with my 555r and had problems grabing so i had to go 4500-5000 which had no problems then.
when testing air psi or putting air in and out do i want to do it when it's cold or hot?
