some electrical problems on a new car
Old Jul 3, 2007 | 04:32 PM
jdm-yoda's Avatar
Default some electrical problems on a new car
So i bought a 94 ej1 shell and ran into a problem after the swap.
My left turning signal stays illuminated when the parking lights/headlights are on. and when the lights are off the climate control and clock blinks as if it were the turning signal
the previous owner had jdm headlights w/citylights and sidemarkers. any ideas? i was thinking maybe a bad ground?
thank you in advance.
Old Jul 3, 2007 | 06:04 PM
jdm-yoda's Avatar
bump b/c i would really appreciate any positive input
Old Jul 4, 2007 | 08:52 AM
jdm-yoda's Avatar
independence day bump guys i need help
Old Jul 4, 2007 | 01:19 PM
dustwalker14's Avatar
Default Re: some electrical problems on a new car (jdm-yoda)
Basic answer sounds like the lines got switched for the clock, climate and the turn signal. If the previous owner had cut the harness when wiring in the side markers etc the wires could have been switched.
Difficult answer could be that the climate control and clock are shorting to ground on the headlight switch but Id check the lines first. If the difficult answer is the case then assume the turn signal is shorting too.
Try and find a body electrical short finder, those things are magic.
Old Jul 4, 2007 | 01:22 PM
spinksy's Avatar
Default Re: (jdm-yoda)
might be a ground wire missing or something?
also ive noticed that sometimes when a bulb goes it interfeers with the rest of the lighting loom
Old Jul 4, 2007 | 04:54 PM
jdm-yoda's Avatar
thank you gentlemen awesome responses i'll check this out
bboixtc
Jul 5, 2008 05:44 PM
SOLO8thGenSi
Honda Civic (2006 - 2015)
13
Jun 4, 2007 04:09 PM
CRXDaddy78155
Oct 3, 2006 12:14 PM
DC2 Mang
Jul 12, 2006 01:47 PM
Toda Party
13
Feb 17, 2003 08:18 AM
