WHEELS WHEELS WHEELS!!! ACCORD EX COUPE V6
OK..SO I HAVE MY 98 ACCORD EX COUPE WITH STOCK WHEELS/TIRES..205/60/16..I NEEDED NEW TIRES..AND FOUND A SET OF TAKE OFF RIMS/TIRES FROM AN 02 RSX..205/55/16..THEY HAD BEEN ADVERTISED AS 215 SIDE WALLS..SO I WAS EXPECTING THE DIFFERENCES TO BALANCE OUT WITH MY SPEEDO..(WIDER TIRE)..AND SO I AM LEFT WITH THE SAME EXACT SIZE TIRES/RIMS..BUT THE DIFFERENCE IS IN THE PROFILE SIZE..SINCE THESE ARE 55 INSTEAD OF 60..HOW WILL MY SPEEDO BE AFFECTED? ANY HELP IS HIGHLY APPRECIATED! THANKS. JOSH
You can use sites like the following to calculated the speedometer difference with both tires:
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Do the 'full analysis' in the above link. There are other sites too; but, the calculation should be the same.
