Question about bigger injectors
Old Jun 7, 2002 | 11:09 AM
Malice's Avatar
New User
Default Question about bigger injectors
I have venom injectors. Venom says they flow 10% better than stock. Since I have bigger injectors, does that make my car richer than normal? If it does, do I have to lean my fuel that much more than normal to compensate for it?
TIA
Old Jun 7, 2002 | 11:19 AM
RTW DC2R's Avatar
Default Re: Question about bigger injectors (MaliceGSR)
im not too sure, but I think if you are running the same fuel pressure, then bigger injectors dont change anything bc the same amount of fuel is coming through the fuel rail. i could be wrong though. just a thought.
Old Jun 7, 2002 | 11:21 AM
sgT's Avatar
sgT
Default Re: Question about bigger injectors (RTW DC2)
wrong you are.
Malice: yes you will run richer, but those injectors are still very close to stock size
so its negligable.
Old Jun 7, 2002 | 11:26 AM
RTW DC2R's Avatar
Default Re: Question about bigger injectors (sgT)
so how does a FPR work then? shouldnt that regulate the amount of fuel that is running in the system?
Malice's Avatar
New User
thanks. does fuel pressure play a role in this as well? i have an AEM FPR
Old Jun 7, 2002 | 11:30 AM
sackdz's Avatar
Default Re: Question about bigger injectors (RTW-DC2)
Fuel pressure will be the same but since you have bigger injections (=higher flow rating), they will pass more fuel in the allotted cycle then the stock. Think of it like a garden hose sprayer, pressure will be more or less the same but the more you squeeze the handle (more flow, bigger opening) the more water will come out in the same amount of time.
[Modified by sackdz, 3:31 PM 6/7/2002]
Old Jun 7, 2002 | 11:31 AM
sgT's Avatar
sgT
pressure will increase/decrease flow rate. To figure flow rate change:
sqrt(new pressure/old pressure) * old flow rate = new flow rate
most injectors are rated at 43psi pressure.
Jan 31, 2010 02:46 PM
B18c1vicrx
Apr 8, 2008 06:21 PM
spurge
Mar 8, 2006 10:56 AM
ATS*Mark
Aug 7, 2004 10:12 AM
NyQuiL
Jul 7, 2003 05:44 PM
