suspension question?
""IF YOU ARE CHANGING JUST THE SPRINGS AND PLAN ON RE-USING THE FACTORY SHOCKS, PAY CLOSE ATTENTION, OTHERWISE SKIP TO THE NEXT STEP. If you notice on the bottom of the spring perch, there are metal tabs protruding on each end. This must be perfectly aligned with the top mount when you reassemble the suspension."" i was just wandring if anyone has picture of the spring perch metal tabs thing.... im doing the gc sleeve swap and i didnt know wat that meant so help
this guy does some koni/GC's on a DC. I know its not quite the answer your looking for but maybe it can lead you in the right direction
https://honda-tech.com/zerothread/1106020
and you might be able to get more help in the suspension forum.
https://honda-tech.com/zeroforum/54
A Blue Lude
15
Jul 8, 2009 12:23 AM
