Performance Cams
Old Jul 3, 2007 | 02:27 PM
Raven_Accord's Avatar
Default Performance Cams
i was thinking about droppin in an h22 and eventually changing out the stock cams for performance cams. i have seen it done, on an h22, and seen great results but my question is whether there would be any other changes to the motor with the performance cams?
Old Jul 3, 2007 | 02:32 PM
Loco-B's Avatar
Default Re: Performance Cams (Raven_Accord)
timing. You would probably want to get a set of adjustable cam gears, given the amount of lift your looking to get from your cams.
You have to keep in mind that advance and retard are key factors when upgrading the cams. And, if not properly tuned you'll be sitting in a hole, trying to figure out why your motor is idling rough, or your valves are bent.
Old Jul 4, 2007 | 10:54 AM
flight50's Avatar
Default Re: Performance Cams (LocOBanAnA)
you should looking into upgrading your ecu/air-fuel ratio. whether chipped or piggy back or stand alone to get better tuning. also depending on the aggression of the cams you get, you might have upgrade the retainers and the springs.
Old Jul 4, 2007 | 04:55 PM
Default Re: Performance Cams (flight50)
thx for the advice, ill try a performance tune up before switching out the cams.
cheaper too, lol.
gurlracer_camille
Feb 4, 2007 08:46 PM
Yellow00TypeR
Feb 16, 2003 10:13 PM
DS1
Sep 3, 2002 10:03 AM
