Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
water in engine?
Old Jul 3, 2007 | 02:07 PM
supertouch's Avatar
Default water in engine?
my car stalled after driving through some areas with particularly high water levels during a heavy rain.
my battery and oil lights came on and the car wouldn't start. after 20 minutes or so, the car started again and i've been able to drive it fine. however, there is a weird buzzing/clicking when i hit the gas.
what do you think is wrong? do you think the problem will go away once the water evaporates?
Old Jul 3, 2007 | 02:11 PM
InanimateCarbonRod's Avatar
Default Re: water in engine? (supertouch)
Do you have a CAI where the filter is particularly low on the car? If so, you've most likely hydrolocked your engine.
Old Jul 3, 2007 | 02:15 PM
fventura03's Avatar
your engine is pretty much done for. it's probably best you stop driving your car until you can get it checked out, so you don't cause any more damage. you've probably bent a rod.
Old Jul 5, 2007 | 03:12 PM
ben98gs's Avatar
I agree with what the others have said. Water does not compress like air does and that wreaks all kids of havoc on the motor when it happens. Without hearing the "clicking" it is hard to diagnose it.
Old Jul 5, 2007 | 07:59 PM
s13_240sx_92's Avatar
you should be able to drive it fine for now if its still running. by now if you did get water in your engine it has "burnt" off. get an old change, pull the plugs, check them out.. run a compression test and see what you find.
Good luck
CRXREFIC
Jun 23, 2010 01:10 AM
dank24
21
Jun 28, 2006 06:34 PM
guero2517
25
Apr 2, 2004 12:21 PM
SkylineGTR
Feb 5, 2004 04:45 PM
SMC Integra
Aug 11, 2003 01:28 PM
