Transmission help/question.
Old Jul 3, 2007 | 01:19 PM
mike9571's Avatar
Default Transmission help/question.
Well I got a transmission from a junkyard for $20. Not that it really matters but the car had 140k on it. The shift linkage was already taken so i wasnt able mess with the gears.
My question...is there any way with out actually putting the tranny in and testing it to know if it is any good? I realize its easy to install a tranny but my buddy wants to buy it if its anygood. I even told him he can install it and if it any good to buy it, if not than take it back out. But he doenst want to.
Old Jul 4, 2007 | 04:37 AM
92_VX_EG's Avatar
Default Re: Transmission help/question. (mike9571)
You can pull the case apart and inspect the internals of the tranny. That's the only way to check it out unless you put it in a car.
Old Jul 4, 2007 | 05:46 AM
Bense's Avatar
you could maybe use x-ray vision to look through the case
I think I found a pair in a cereal box with I was 8, haven't seen them since. Sorry Bro.
Old Jul 4, 2007 | 11:24 AM
mike9571's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">you could maybe use x-ray vision to look through the case
I think I found a pair in a cereal box with I was 8, haven't seen them since. Sorry Bro.</TD></TR></TABLE>
I have x-ray so that wont be a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VX_EG &raquo;</TD></TR><TR><TD CLASS="quote">You can pull the case apart and inspect the internals of the tranny. That's the only way to check it out unless you put it in a car.</TD></TR></TABLE>
Well im going to take the case apart because I want to learn a little about transmissions. What do I look for? Broken teeth, metal shavings?...
Old Jul 4, 2007 | 11:29 AM
Bense's Avatar
Default Re: (mike9571)
https://honda-tech.com/zerothread/1916635
Old Jul 4, 2007 | 06:24 PM
Mista Bone's Avatar
D Tranny Guru
who needs X ray glasses
I just grab the shaft, wiggle it......talk to it in a manly voice......smell the fluid......
passed over quite a few trannys like that
ReactioN
Jun 3, 2008 11:31 AM
Rex-Si
Jun 24, 2006 04:16 PM
sanjiyan69
Jul 9, 2004 07:29 PM
Mr HYDE
May 10, 2004 07:45 PM
HaUTSaauce
Jun 5, 2003 07:37 PM
