Is the thread pitch for the vtec pressure switch the same is the engine oil pressure switch?
Old Jul 3, 2007 | 09:52 AM
white90rexsi's Avatar
Default Is the thread pitch for the vtec pressure switch the same is the engine oil pressure switch?
Hey. I have an obd2 gsr engine that does not have a vtec pressure switch. I need to run one for my ecu so I need to drill and tap the hole in this solenoid. I ordered a switch from honda but it is not here tull friday. I would like to drill and tap my solenoid now but I dont know the thread pitch. I have a engine oil pressure switch right here and I wanted to know if it is the same thread pitch as the vtec oil pressure switch?
-Chris
Old Jul 3, 2007 | 10:05 AM
Smokinsax's Avatar
The Boot
wow...you have to be a honda guru/god to know the answer to that question.
I would ASSume that they would be the same. K.I.S.S. would be a Honda understatement.
Old Jul 3, 2007 | 10:08 AM
Default Re: (Smokinsax)
I am assuming as well but what I do NOT want to happen is me tap it out to the engine oil pressure switch then go to install the v-tec oil pressure switch when it gets here and have it be wrong. So, does anyone know for sure?
streetracerof06
May 9, 2006 05:09 PM
wannagofaster
Sep 4, 2004 03:25 PM
