Looking for help w/ 2002 accord immobilzer / ECU programming
Hey guys...
I bought a 2002 accord ...it had been in the water. Had all the wiring harnesses, ECU, ignition, the engine, etc... replaced. (I'm in deep now) I'm now down to the ignition/security system. AS I understand it...the ECU has the immobilizer built in...or running through it. As it is...it wont pulse the injectors, no fuel.
Is there anyway around dealer programming, etc.
The ecu i bought was from a j-yard....as well as the ignition and key.
As I "dont" understand it...It needs to be towed to the dealer to have the ecu and ignition and key...all programmed to match? Is this the process?...Anyone with knowledge of the same..and a possible (at least temporary) workaround, Would be greatly appreciated.
Modified by adaddo at 3:08 PM 7/3/2007
Modified by adaddo at 2:57 AM 7/4/2007
82.00 for programming
55.82 for the new programmed key
4.92 shop fees
146.09 ...out the door
....Coulda been worse
Thx all !!!, .. for the IM's and the responses to my confusing questions
4.92 shop fees
2001, 2007, accord, ecu, find, honda, ignition, immobilizer, key, pcm, programing, programmer, programming, reprogramming, work
