???? HELP!!!! IS IT MY AXELS?, MOTOR MOUNT? OR????
Old Jul 3, 2007 | 02:10 AM
i_VTEC's Avatar
Default ???? HELP!!!! IS IT MY AXELS?, MOTOR MOUNT? OR????
I have a slight problem. . . Every time i change gears and give my CRX a little gas i hear this clinging sound (like a broken motor mount) But i checked my motor mounts and they are fine. Or so i think. My Axels were needing to be replaced when i bought the car, but now they seem to be worse. I was told that this "sound" i am hearing is from my axels that got worse and or broken. I'm not too sure though because if i down shift i can feel my shifter pushing back against my hand if you know what i mean??????
If you have any idea what this problem may be caused by PLEASE let me know!!! I want to this problem fixed!!!
Old Jul 3, 2007 | 04:36 AM
white90rexsi's Avatar
Default Re: ???? HELP!!!! IS IT MY AXELS?, MOTOR MOUNT? OR???? (LS-VRex)
Have you checked to make sure all your motor mounts are tight? Also check the front and rear subframe bolts to make sure they are tight.
Old Jul 3, 2007 | 05:08 AM
ludesrv's Avatar
Well the easiest way to check is to replace the axles. Give all the major components of the suspension a quick go over, maybe hit the front cross member with a torque wrench.
Old Jul 3, 2007 | 12:54 PM
i_VTEC's Avatar
Default Re: (ludesrv)
Ill make sure to check all of that. . . Thanks again!
Old Jul 3, 2007 | 01:02 PM
503_EF9's Avatar
Default Re: (LS-VRex)
ya its good to get new axles in anyways. make sure to use lots of lube everywhere.
Old Jul 3, 2007 | 03:33 PM
i_VTEC's Avatar
Default Re: (503_EF9)
Yeah for sure!! Haha. I hope that its just my Axles and not something major!
Old Jul 4, 2007 | 12:10 PM
503_EF9's Avatar
well theyres not much that can happen between your gears and the wheels
so its tranny problems of some sort and thats not to big anyways or axles.
tell me how it turns out.
Old Oct 3, 2007 | 05:07 PM
JdMJUnkIe7360's Avatar
Default Re: ???? HELP!!!! IS IT MY AXELS?, MOTOR MOUNT? OR???? (white90rexsi)
its deffinatly your motor mount because mine busted and it was doing the same thing that you have just described, so it needs to be replaced asap, dont get on it twists the other motor like crazy.
98civtec
Jun 7, 2009 05:20 PM
GEOz2k7
Oct 30, 2008 11:08 PM
whitehf
Mar 3, 2006 02:44 PM
Mr.Saturn
Nov 8, 2003 04:28 AM
BigBank420
Dec 4, 2002 12:00 PM
