some wiring questions
Old Jul 2, 2007 | 10:26 PM
ef dino's Avatar
Default some wiring questions
Can someone give me a diagram for all the wires reguired for the water temp sensor, fan, and gauge?
And also a wiring diagram for the reverse lights?
Old Jul 3, 2007 | 07:22 AM
ef dino's Avatar
Default Re: some wiring questions (*****please)
anything? from anybody?
this is for a b16 rex if that makes it any different
Old Jul 3, 2007 | 08:30 AM
mahatma's Avatar
wiring diagram where? in the engine bay? at the ecu? i don't have either but
fan is the green plug down below the passenger headlight area.
temp gauge sensor hooks up under the distributor, in the head.
fan switch for obd0 motor is the 2-prong plug in the back of the block, near the oil filter.
do you have a specific problem? hacked wiring harness? overheating? crazy temp reading?
Old Jul 3, 2007 | 08:34 AM
ef dino's Avatar
Default Re: some wiring questions (mahatma)
Im doing a wire tuck right now..Before i started though the fan would never turn on and it would just overheat all the time, so i just hooked the fan up to an external switch but it would be 10 times easier if i can do it the right way.
And i have no idea where the reverse lights wiring would be.
Old Jul 3, 2007 | 09:18 AM
mahatma's Avatar
reverse lights i can't remember sorry.... (try asking in the EF forum)
but the fan switch should be the big 2 pin plug on the back of the block if it's obd0. on obd1 motors the fan switch plugs into the *brown* plug on the thermostat housing. either location should work.
if your fan stopped working, check the relay also by the passenger headlight. the fan plug wires should be coming directly from that relay.
Old Jul 3, 2007 | 10:00 AM
ef dino's Avatar
EF forum will do.. thanks for the help.
may i ask what the bov you want is for?
Old Jul 3, 2007 | 10:34 AM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by *****please &raquo;</TD></TR><TR><TD CLASS="quote">may i ask what the bov you want is for?</TD></TR></TABLE>
i have a type-s but want to attach the blue "horn" piece i have from a type-rs. it threads on, so i want to rig a portion of the rs housing onto my s.
i'm a ricer
Old Jul 3, 2007 | 01:07 PM
ef dino's Avatar
haha..
one more question, the two wires that come out of the back of the block go where. and how does the fan hook up to those two wires.
Old Jul 3, 2007 | 09:10 PM
ef dino's Avatar
Default Re: some wiring questions (ef dino)
Old Jul 4, 2007 | 11:25 AM
ef dino's Avatar
How do all those wires come together though, i have my harness completely untaped and apart. First im working on a dizzy problem i had. Now how do all the fan wires hook up to the sensor under the dizzy, and the sensor in the back of the block? And the sensor next to the one under the dizzy has a red/white wire and a green one coming out of it. Whats that, one of those wires was cut by someone else.. and im just trying to get everything back to the way it should be if not better.
Doepy
Oct 5, 2017 08:37 AM
scottmog
Dec 23, 2009 12:53 PM
dannysolis92005
12
Jul 27, 2009 10:59 AM
