where is the IACV on 97 prelude?
Old Jul 2, 2007 | 08:45 PM
j-rome's Avatar
Default where is the IACV on 97 prelude?
well my brother just bought a prelude and its ideling funny until it warms up. We asked the previous owner as we just bought it a few days agao and he said he had to clean the IACV when it happend to him. just woundering where it is? I want to say its the black thing with the grey plug connected to it on top of the throttle body? or no?
Old Jul 2, 2007 | 09:06 PM
mattsnooz's Avatar
Default Re: where is the IACV on 97 prelude? (j-rome)
no. its the part connected on manifold right below throttle linkage. It has a two port quick connector plugging into it, as well as two coolant lines at bottom of it (one on either side) Its held on by 3 x 12mm bolts. If you remove the bottom lines some coolant might come out (if cars warm) (to identify IACV the long center bolt that sticks out right under the throttle linkage is where IACV is (on your pic)
or 3 oclock from oil filler cap (for ya militery folks)
Modified by mattsnooz at 7:53 AM 7/3/2007
Old Jul 2, 2007 | 09:15 PM
j-rome's Avatar
this? (circled red)
Old Jul 2, 2007 | 09:20 PM
Hawkze_2.3's Avatar
Default Re: (j-rome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-rome &raquo;</TD></TR><TR><TD CLASS="quote">this? (circled red)
No, it's to the right of that...with the coolant hoses coming off of it. Try using the search button.
Old Jul 2, 2007 | 09:22 PM
mattsnooz's Avatar
thats 9 oclock...jesus...3 oclock, is up and to the right
Old Jul 3, 2007 | 03:40 AM
j-rome's Avatar
Default Re: (mattsnooz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">thats 9 oclock...jesus...3 oclock, is up and to the right</TD></TR></TABLE>
i know but the part that i was confused about was you said it was connected to the throttle body. but either way i think i see it now.
thanks
Old Jul 3, 2007 | 03:52 AM
adam62882's Avatar
right here:
Old Jul 3, 2007 | 06:59 AM
mattsnooz's Avatar
yeah your right, I'm sorry. You refered to it as the "throttle body" I thought, so I used the same word so you would understand the part I was talking about. Its called the Intake manifold, so I'll stick to using the proper names of things so I don't confuse you.
Oh, how about a vacuum leak? that causes wierd idling issues only during "warm up" phase. If you've modded it at all check your CAI/SRI straps, check your throttle body to see if its bolts are tightend to your intake manifold. Then, maybe check Intake Manifold gasket/bolts. I had a loose bolt and my intake manifold would make a screaming noise occasionally, from air vibrating with the gasket.
I'd start with vacuum leaks b4 your IACV/EACV. Your motor looks pretty clean/new to have a super clogged IACV.
Old Jul 3, 2007 | 12:41 PM
j-rome's Avatar
Default Re: (adam62882)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam62882 &raquo;</TD></TR><TR><TD CLASS="quote">right here:
thank you thats what i thought the 2nd time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">yeah your right, I'm sorry. You refered to it as the "throttle body" I thought, so I used the same word so you would understand the part I was talking about. Its called the Intake manifold, so I'll stick to using the proper names of things so I don't confuse you.
I'd start with vacuum leaks b4 your IACV/EACV. Your motor looks pretty clean/new to have a super clogged IACV. </TD></TR></TABLE>
ill look for vacuum leaks. the engine was bored out by the previous owner by a trustworthy shop. so it was completely rebuilt so i guess their is a good possibility of a vacuum leak.
thanks for the help. ill let you know what i find out.
94Prelude94
Engine Management and Tuning
Nov 30, 2012 06:21 AM
civic_driver
97
Jul 27, 2007 06:28 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
F22Platano
Aug 11, 2005 09:23 PM
