coolant leak through the upper radiator hose
Old Jul 2, 2007 | 07:52 PM
Ritchie's Avatar
Default coolant leak through the upper radiator hose
recently i'm experiencing a coolant leak on my 92 honda civic with d16z6 swap. the leak is coming from the upper radiator hose. the hose was replaced and i even push it in some more hoping it will stop the leak. i even tried bleeding the radiator by taking off the cap and let the car idle. coolant will fill up to the top, but once the fan turns on, it will go down. whenever i drive, it will continue leak. anyone have any suggestions? could this be the radiator problem?
Old Jul 2, 2007 | 08:20 PM
Mr.EM1_EK's Avatar
Default Re: coolant leak through the upper radiator hose (HondaEGG)
maybe the clamp holding your hose is not that tight. could be the wrong cap maybe, causing too much pressure to build up.
Old Jul 2, 2007 | 08:22 PM
Ritchie's Avatar
Default Re: coolant leak through the upper radiator hose (Mr.EM1_EK)
Hmm, the clamp should be good since I bought it new. Radiator cap might be bad since I don't even know how old it is. Could there be any possibilities? Maybe a bad radiator?
chawski
Honda Civic (2001 - 2005)
Jan 1, 2014 02:20 PM
Soooogie
Sep 29, 2013 04:54 AM
thechineseone
Mar 16, 2009 09:33 AM
PatrickGSR94
Aug 19, 2008 03:48 AM
ALLMOTORD16Z6
May 20, 2005 03:27 AM
