98 obdII GS-r Misfire - Emergency Please Help!
Old Jul 2, 2007 | 06:12 PM
Ra GS-R's Avatar
Default 98 obdII GS-r Misfire - Emergency Please Help!
I have a 98 gsr and i was doinga really in depth detail on it which involved pressure washing the motor, after this on my way home (5 miles) it began to misfire and check engine light was flashing. when i got home i opened up the distributer cap and let it sit overnigt hoping it would evaporate all the moisture. tHe next morning I noticed the a nipple on the evap puge control solenoid was cracked. so i replaced it and reset the ecu. When i started it up it was cool for a little bit, but then it started misfiring again and check engine light blinking again.
Someone please help!
Old Jul 2, 2007 | 06:19 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 98 obdII GS-r Misfire - Emergency Please Help! (beanstalk805@hotmail.com)
Adjust valves
Compression test
Are there any CELs stored?
Old Jul 2, 2007 | 06:25 PM
Ra GS-R's Avatar
Default Re: 98 obdII GS-r Misfire - Emergency Please Help! (Dogginator)
CEl's
Old Jul 2, 2007 | 06:26 PM
Dogginator's Avatar
Daisy... Daisy...
Check engine lights. You 98 GSR should be able to provide details as to why it is misfiring. Look at the Integra FAQ thread for CEL details.
Old Jul 2, 2007 | 06:27 PM
Ra GS-R's Avatar
well i think i may just need a valve adjustment then, but why would pressure washing it cause a need for those things
Old Jul 2, 2007 | 06:39 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beanstalk805@hotmail.com &raquo;</TD></TR><TR><TD CLASS="quote">well i think i may just need a valve adjustment then, but why would pressure washing it cause a need for those things</TD></TR></TABLE>
I missed that part about the pressure washing. Pull the CELs to see if all of the cylinders are misfiring. You are most likely correct about the cap. Just let the CELs guide your diagnosis.
Old Jul 2, 2007 | 07:56 PM
Ra GS-R's Avatar
so what if the tech tells me i need a valve adjustment should i believe him or what? b/c how could that be coused by pressure washing, wht should i do about the cap?
Old Jul 3, 2007 | 01:48 PM
Ra GS-R's Avatar
oh i figured it out water in spark plug holes and wires shorted out
Old Jul 3, 2007 | 01:54 PM
MadVtak's Avatar
* B A N N E D *
From: Biggest Baddest Little City in The World RENO, NV
Woohoo! thats the best!
SilverG1Teg
Oct 7, 2009 06:58 AM
ttvraines
Sep 26, 2006 06:31 AM
OneOver
Oct 29, 2004 11:15 AM
davidjaii
Oct 20, 2003 02:46 PM
