KEYLESS REMOTE INSTRUCTIONS
Old Jul 2, 2007 | 06:06 PM
power11's Avatar
Default KEYLESS REMOTE INSTRUCTIONS
does anyone have instructions to pragram an oem keyless remote to the car? i have a 2000 honda accord EX. untructions would help a lot!
Old Jul 7, 2007 | 03:36 PM
rardyboy's Avatar
Default Re: KEYLESS REMOTE INSTRUCTIONS (power11)
Hi, I have a 2001 Accord EX and did exactly what these instructions said and did not have any problems.
http://www.collegehillshonda.c...shtml
Old Jul 7, 2007 | 03:40 PM
rardyboy's Avatar
Default Re: KEYLESS REMOTE INSTRUCTIONS (rardyboy)
NOTES:
• The system accepts up to three transmitters. The transmitter codes are stored in a stacking-type memory. If a fourth transmitter code is programmed, the code for the first transmitter is erased.
• Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all of the transmitters once you are in the programming mode.
• You must complete steps 1–6 within 4 seconds of the previous step to keep the system from exiting the programming mode.
Programming the Transmitter
1. Turn the ignition switch to ON (II).
2. Press the “Lock” or “Unlock” button on one of the transmitters. (An unprogrammed transmitter can be used for this step.)
3. Turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times using the same transmitter used in step 2.
5. Turn the ignition switch to ON (II).
6. Press the “Lock” or “Unlock” button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode.
7. Within 10 seconds, press the “Lock” or “Unlock” button on each transmitter. Make sure the power door locks cycle after you press each transmitter button to confirm that the system accepted the transmitter’s code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
Ordering a Transmitter
You may order direct from College Hills Honda. Simply call 1-888-244-6632 and ask for Internet Parts.
Batteries for the Transmitter
The battery number is CR2025. Each transmitter uses one battery.
Texasbo56
Apr 12, 2018 08:06 AM
mikesacchetti
Jan 31, 2018 04:14 PM
modee80
Aug 14, 2010 09:03 AM
04Si
Jun 6, 2007 01:35 PM
mudfootball
Sep 5, 2004 01:00 PM
