PVC breather system on b20/vtec after its built help please
Old Jul 2, 2007 | 05:52 PM
Zalitore's Avatar
Default PVC breather system on b20/vtec after its built help please
ok soo another question. i got a b20 vtec built and there was never a pvc system implemented, now i dont want to take it apart so i can drill and tap a fitting for it and i dont want to drill adn tap it now and get debree in there.
soo what are some suggestions ive done quick searching but havent come up with any solid imformation aside from putting a fitting in the large plug at the back of the block.. ?
Old Jul 3, 2007 | 06:09 AM
b20beast978's Avatar
endyne makes a nice breather kit for about 175 i believe..check it out
Old Jul 3, 2007 | 05:00 PM
BeniRacing's Avatar
Default Re: (b20beast978)
True the edyne kit its nice. Only hard part about the install is finding a 14mm allen socket to take out the plugs on the motor.
Old Jul 3, 2007 | 05:12 PM
Default Re: (BeniRacing)
yea that sux ***
Old Jul 4, 2007 | 06:58 PM
Zalitore's Avatar
Default Re: PVC breather system on b20/vtec after its built help please (Zalitore)
endyne eh ? alright thansk a ton, now that i think about it i saw that kit a while back reasearching everything.
Old Jul 4, 2007 | 07:13 PM
Zalitore's Avatar
another question about it that i never really found an answer to in my research.
A. do you need to add a little extra oil for when the crank vents and pushes the oil into the can ?
B. does it have to be pressurized in anyway ? i saw a kit on here where hmmm i forget his name had one built with 2 breathers ontop, 2 off the valve cover, and 2 into the back of the block.
AllMotorDA9
Mar 11, 2008 02:47 AM
urtz
Dec 9, 2006 02:50 PM
CrVtecEk
Dec 3, 2003 11:58 AM
