ram air duct
Old Jul 2, 2007 | 05:20 PM
dohc_profile's Avatar
Default ram air duct
how do i remove the ram air duct from my dc4, i bought an aem v2 intake and dont know how to take out the bottom air box. thanks.
Old Jul 2, 2007 | 05:40 PM
TEGGSRB18C1's Avatar
Default Re: ram air duct (dohc_profile)
First remove the panel underneath the radiator, the one that spans from wheel well to wheel well.
Next remove the passenger side wheel and unclip the wheel well half way around. You should be able to pull the wheel well behind the brake assembly.
From there just look for all the bolts holdin the OEM air box in place. You might need some air tools to break loose the trans mount from the lower torque mount, mine was pretty ******* tight.
You also need to torque the new trans mount down to 60ft lbs if I remember correctly. Didn't you recieve instructions w/ your intake?
triple
Jun 8, 2010 08:09 PM
FIGARILA
Sep 10, 2009 10:07 PM
ProjectLudeSiR
Aug 22, 2005 08:17 AM
crashtest Sonny
Jan 4, 2004 08:42 PM
pyrojeff
Jan 17, 2003 07:40 PM
