nonOBD vs OBD1/2
Old Jun 7, 2002 | 08:33 AM
Eggman's Avatar
Default nonOBD vs OBD1/2
anyone have dynos comparing a nonOBD car before and after converting to OBD?
Old Jun 12, 2002 | 02:16 PM
Eggman's Avatar
Default Re: nonOBD vs OBD1/2 (Eggman)
Old Jun 12, 2002 | 08:49 PM
StorminMatt's Avatar
To which motor are you referring? The power gains all depend on which motor you are talking about. Actually, there is little difference between 'OBD0' and 'OBDI'. In fact, the setup commonly referred to as 'OBD0' is really nothing more than an earlier version of what is referred to as 'OBD1'. After all, 1988-1991 ECUs DO have an on board diagnostics system. When it comes to performance, the two systems ('OBD0' and 'OBD1') are actually quite equal as well. It is only when you use an 'OBD0' ECU intended for a less powerful motor that power output suffers (ie stock SI ECU with D16Z6, 1990-1991 PR4 ECU with a 1992+ B18A/B18B, or PR3/PW0 with a B18C).
Old Jun 13, 2002 | 08:56 AM
Eggman's Avatar
Default Re: nonOBD vs OBD1/2 (StorminMatt)
well on a b18 vtec powered by a nonOBD pr3. its a obd-1 motor and a nonOBD ecu. but hey, at least its a vtec ecu \
egboostin6
Apr 19, 2007 08:36 PM
jdmsijdm
Jan 4, 2005 08:45 AM
Maddox
Apr 5, 2004 07:03 PM
ViperRedCRX
May 19, 2003 01:01 PM
