Bosch Universal o2 Sensor Question
I see that theres 2 white wire (heater wires) so my question is one of the wire suppose to get power (12 volt) to it? And usually the black wire is the Signal wire which sends the data to the ECU? And it doesnt matter if i switch the polarity to the White wire (heater wire)?
https://honda-tech.com/zerothread?id=1712487
https://honda-tech.com/zerothread?id=1381574
https://honda-tech.com/zerothread?id=1381585
etc
please search next time
(doing so would have not only told you how to wire that thing, but also not to have purchased it in the first place
Take it back, theyre junk, get a denso.
period
etc
)Take it back, theyre junk, get a denso.
period
you can polorize the heater either way, it is just a heating element It will work the same regardless of the polarity!
Drew
Modified by cool_junk at 10:12 PM 7/2/2007
Drew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cool_junk »</TD></TR><TR><TD CLASS="quote">you can polorize the heater either way, it is just a heating element It will work the same regardless of the polarity! Don't worry I don't search either!
Drew</TD></TR></TABLE>
tsk tsk... you will be flamed to hell and may not last here long..
genocide43110
Dec 12, 2006 02:09 PM
93ludeSi
Nov 15, 2003 08:02 PM
