How to wire up foglights on 96 accord using relays?
Old Jul 2, 2007 | 03:23 PM
hackdaccord's Avatar
Default How to wire up foglights on 96 accord using relays?
I have the factory fog button that goes next to the hazard button. I want to use it to run power to my fogs. Im sure that I have to put a relay in the line im just not sure of what kind and how to?
Old Jul 2, 2007 | 04:52 PM
Default Re: How to wire up foglights on 96 accord using relays? (hackdaccord)
somebody knows!?
Old Jul 4, 2007 | 01:22 PM
Old Jul 4, 2007 | 01:29 PM
TheMuffinMan's Avatar
He knows where you live!
My guess would be a DPST relay? I think that's correct
Double Pole Single Throw?
god I haven't played with relays in forever, if you don't already have the fog lights on your bumper, why not just buy a $40 OEM style one from ebay, and have everything included (wire harness, fogs, relays, etc)
Old Jul 4, 2007 | 04:50 PM
Hammer99ex's Avatar
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">My guess would be a DPST relay? I think that's correct
that sounds more like a household light switch... lol
your relay uses small current to control big current. from what i remember, there should be 4 or 5 prongs on the bottom of the relay that match numbers imprinted on the top of it. 50 and 64 is the big current portion of the relay(could be wrong on #64. someone please correct me if thats the case.), and 86 and 87 is the small current side id run the power wire from your fog switch to #87, and 86 to ground. then connect battery voltage to #50, and wire your fog lights power to #64. then ground out the lights. now, some relays are different, thats why i said either 4 or 5 prong. the 5th prong (if ur relay has it) can either be useless, or used to power something else when the fogs are off. if u dont use it, then its more like a resting place for the switch inside the relay.
its been 2 years since ive taken a nap in electrical class @ auto school. i know i have the right idea, but i may be wrong on the numbers.
hope this helps!
Accord34legacy
Nov 29, 2010 06:29 PM
4DRmafia
Audio / Security / Video
Sep 14, 2004 07:45 PM
B18EG6
Jul 26, 2004 03:47 PM
caliriptide
Mar 11, 2004 06:25 PM
integra99blue
Aug 16, 2001 09:49 PM
