Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
Old Jul 2, 2007 | 01:17 PM
b20vtech's Avatar
Default Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation!
I personally use regular non-syntetic 5w30 motor oil on Cylinder wall prep before piston installations, but have seen and herd of so many other things people use... Please help me find out the best solution there is.... btw if im missing anyother stuff that should of been on my poll list plz feel free to inform me......
Old Jul 2, 2007 | 01:47 PM
MAX_CFM's Avatar
Default Re: Egine Builder's, Polls on what lubricant to lub up Cylinder walls before Piston installation! (b
This is what Pro Engine Builders Use .. A tight Dry hole is a bad thing
Old Jul 2, 2007 | 02:38 PM
d15Beta's Avatar
LOL hahahahaahahahahaha
Old Jul 2, 2007 | 02:48 PM
b20vtech's Avatar
lol, no they don't.
Old Jul 2, 2007 | 03:21 PM
WHTZ's Avatar
ILMAO!!!!!!!!!!!!!!!!!!
Old Jul 2, 2007 | 03:37 PM
96Spec Ek's Avatar
Straight 30 weight oil, non detergent.
Old Jul 2, 2007 | 03:52 PM
DonF's Avatar
Default Re: (96Spec Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek &raquo;</TD></TR><TR><TD CLASS="quote">Straight 30 weight oil, non detergent.</TD></TR></TABLE> This worked better than what other combinations? What did you have problems with? Did this break-in faster or slower than other options? Did the ring life last longer?
Old Jul 2, 2007 | 04:04 PM
Dyno Dave's Avatar
I have been using WD40 for many years and never to this day never had a ring or piston failure from using it on first startup and find the rings seat very quickly.
Regards Dyno Dave
Modified by Dyno Dave at 1:03 AM 7/4/2007
Old Jul 2, 2007 | 04:12 PM
Jay_Sensing's Avatar
In my vast experience of like, 10 motors lol, I have used WD 40 on all of them. Maybe not the best, but definitely not the worst since none of them died an untimely death.
Old Jul 2, 2007 | 04:44 PM
b20vtech's Avatar
My machinist uses wd40 on the walls before he installs the pistons, and after couple of turns rotating the crank, it makes little dark scratches up and down the walls... Now would that be because he was using wd40 or is it just normal like that???
Old Jul 2, 2007 | 04:56 PM
b19coupe's Avatar
I have been using WD40 for years too.
Old Jul 2, 2007 | 05:21 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">This is what Pro Engine Builders Use .. A tight Dry hole is a bad thing
LOL
sorry!
Old Jul 2, 2007 | 07:05 PM
b18bEKcoupe's Avatar
Who said synthetic?
Old Jul 2, 2007 | 07:46 PM
Natural Aspirations's Avatar
MMO anyone?
Old Jul 2, 2007 | 07:55 PM
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">MMO anyone?</TD></TR></TABLE>
Its a mystery to me.
Old Jul 2, 2007 | 07:56 PM
Runnerdown's Avatar
I use MMO!! Then the engine runs for about a half an hour before going onto the dyno. 24 inches of vacuum (small cams) and no smoke tells me its working well.
Last time I tried oil was when I put a snowblower engine together in high school. Since then has been wd-40 and mmo.
Old Jul 3, 2007 | 03:56 AM
1 2 NV's Avatar
Default Re: (Runnerdown)
i use ATF.
Old Jul 3, 2007 | 07:15 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (1 2 NV)
i'm prob gonna use torco
Old Jul 3, 2007 | 07:39 AM
AutotechRD's Avatar
Why not use the dry-lube from Total Seal. I would be willing to bet that every team in Pro-Stock uses it...
Old Jul 3, 2007 | 09:04 AM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutotechRD &raquo;</TD></TR><TR><TD CLASS="quote">Why not use the dry-lube from Total Seal. I would be willing to bet that every team in Pro-Stock uses it...</TD></TR></TABLE> And thy replace the pistons and rings when? After how many minuets of run time?
I vote for MMO or WD40 after cleaning with acetone.
Old Jul 3, 2007 | 01:41 PM
Broken Gearbox's Avatar
At the machine shop i work at we use WD40.
Old Jul 3, 2007 | 04:10 PM
Mike K's Avatar
Default Re: (Broken Gearbox)
i always use HondaLube. it's just like WD-40, but i get it free at work.
Old Jul 3, 2007 | 08:10 PM
hayabusa160's Avatar
Default Re: (Mike K)
haha honda lube great stuff.
i love using it at work seems to work better then wd40 imo
Old Jul 3, 2007 | 09:43 PM
Combustion Contraption's Avatar
Interesting. Ive never tried it. I have never found an anerobic sealant that works as well as Honda-Bond tho, so if the results are anything like that, it could be quite good.
Old Jul 4, 2007 | 11:58 AM
kpowerdhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i use ATF.</TD></TR></TABLE>
Me too.
