i have a question
although you will still have an engine with tiny little rod and main journals on the crankshaft and valve reliefs for only 8 valves, not 16 - with the small crankshaft, don't expect it to last very long if you run it up beyond around 5500 rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">although you will still have an engine with tiny little rod and main journals on the crankshaft and valve reliefs for only 8 valves, not 16 - with the small crankshaft, don't expect it to last very long if you run it up beyond around 5500 rpm</TD></TR></TABLE>
ROFLMAO.............so true though.....
Very true. OP, you may be able to score a D15B2 block for cheap, then use that as your starting base for the mini me.
jsmithrn
Apr 26, 2007 12:14 PM
