idle
Vacuum leak or stucked EACV.
1. take the intake pipe off and block with your thumb the hole to the left side of the throttle body ( inside the TB ) If there are two holes block both.
If the idle drops, then the EACV is clogged. You can fix it temporarily by removing it and cleaning it with carb cleaner.
2. If #1 didn't help. you have a vacuum leak probably at the brake booster.
Good luck.
Good luck.
mgags7
Jan 30, 2025 08:58 AM
sik_sol
Aug 18, 2006 02:08 PM
FlatLineEG8
Mar 4, 2004 04:47 PM
