What are the pros and cons between the k24a1 and k24a2?
Old Jul 2, 2007 | 09:32 AM
jdmdc5integra's Avatar
Default What are the pros and cons between the k24a1 and k24a2?
I want to do a frank swap with k20a2 head and don't know the differences if any between the two blocks! Also does it matter if they are long block or short block?
Old Jul 2, 2007 | 10:36 AM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: What are the pros and cons between the k24a1 and k24a2? (jdmdc5integra)
a shortblock is just the bottom end, which is usually cheaper. a longblock is the entire engine (head & block). i would personally try to get a k24a2 instead of the a1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teampacman from k20a.org &raquo;</TD></TR><TR><TD CLASS="quote">
K24A1
Found in:
2002-2006 Honda CR-V
Displacement: 2354 cc
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (119 kW) @ 6000 rpm
Torque: 162 ft·lbf (220 N·m) @ 3600 rpm
Redline: 6500 rpm
K24A2
Found in:
2004-2006 Acura TSX
Compression: 10.5:1
Power: 205 hp (149 kW) @ 6800 rpm
Torque: 166 ft·lbf (225 N·m) @ 4500 rpm
Redline: 7100 rpm
Old Jul 2, 2007 | 12:03 PM
Default Re: What are the pros and cons between the k24a1 and k24a2? (4F CHR!S)
Ok, now I see!! Eventually I want to go F/i, so would the a2 still be better or the a1?
Old Jul 2, 2007 | 12:15 PM
KOREAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc5integra &raquo;</TD></TR><TR><TD CLASS="quote">Ok, now I see!! Eventually I want to go F/i, so would the a2 still be better or the a1? </TD></TR></TABLE>
Depends... will you lower the compression on the k24a2? If not, go with the a1
Old Jul 2, 2007 | 12:19 PM
Default Re: What are the pros and cons between the k24a1 and k24a2? (korean)
I heard the k24a2 costs alot more then the k24a1?...........
Old Jul 2, 2007 | 12:43 PM
The Bagel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdc5integra &raquo;</TD></TR><TR><TD CLASS="quote">I heard the k24a2 costs alot more then the k24a1?........... </TD></TR></TABLE>
About a half hour of research will get you an answer to that.
https://honda-tech.com/zerothread/1845097
Try this
Modified by The Bagel at 5:11 PM 7/2/2007
ef-b16sedan
Aug 22, 2010 11:05 PM
matt94z
Apr 21, 2009 10:48 PM
square_1
15
Dec 24, 2007 06:47 AM
