Phillips HID kit (4000k?) Difference in fitment for 97, 98 and 00 itr?
Old Jun 7, 2002 | 07:15 AM
Black R's Avatar
25 Year Member
Default Phillips HID kit (4000k?) Difference in fitment for 97, 98 and 00 itr?
If I buy a used kit, what bulbs should I make sure I'm getting?
Also, is there a difference in the fitment or in which kit to get for the itr (depending on the year)?
Old Jun 7, 2002 | 08:54 AM
Black R's Avatar
25 Year Member
Default Re: Phillips HID kit (4000k?) Difference in fitment for 97, 98 and 00 itr? (Black R)
....should this be the 9006 for low beams too?
Old Jun 7, 2002 | 09:20 AM
Rboosted717's Avatar
same kit for each year and make sure you get D2S bulbs that are modd'd for a 9006 type socket.
Old Jun 7, 2002 | 09:21 AM
Austin's Avatar
Default Re: Phillips HID kit (Rboosted717)
I was waiting for a reply from an HID fiend...
Old Jun 7, 2002 | 09:22 AM
Default Re: Phillips HID kit (Austin)
actually I havn't posted on most of the HID threads since everyone here seems to have learned more about them and give good advice. Saves me the time. However since it was black R's thread I felt I should post on it for him.
Old Jun 7, 2002 | 10:20 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
R boosted if you are know alot about HID's can I ask a ?........How would a Phillips style HID conversion kit look in a 92-95 Civic (H4 blub).
I have been looking @ getting this because I hate blue lights and the stock lights to me don't put out as much light!!!?!!!!!
Old Jun 7, 2002 | 11:30 AM
Default Re: Phillips HID kit (Apex i ITR)
they would be good for that car. Just make sure you get the D2R bulbs with H4 sockets on them. Since you don't have projector type headlights you need the D2R bulbs.
The light output will be a lot better then stock and TONS better then blue bulbs.
Old Jun 7, 2002 | 11:58 AM
RiCE On IcE 2's Avatar
If u dun wanan spring the 600 or so for HID u coudl get some piaas.. they come off white.. no blue.. and are brighter then stock.. although I hears some piaas have blown out after a year? I jsut got the japanese xtreme whites... they look pretty good actually.. and they are liek 109 actually they are rated at 4150K.. shouldnt; teh HID's be more arodun 5 or 6K? 4K seems kinda low for HID
[Modified by scmdl26, 8:58 PM 6/7/2002]
Old Jun 7, 2002 | 12:04 PM
B2FiNiTY's Avatar
Default Re: Phillips HID kit (scmdl26)
The K means Kevlin which is color temp and basically just determines the color that the bulb puts out. HIDs are WAY better than the PIAAs and they last very very long.
Old Jun 7, 2002 | 12:17 PM
Default Re: Phillips HID kit (B2FiNiTY)
I know HID are way better then PIAA and I know wut the K is.. I'm just saying 4000K is way low for HID.. shoudl be about 1000 higher.. unless it's the first gen HID.. which was liek 4000
Old Jun 7, 2002 | 12:28 PM
acutally most all factory HID bulbs are rated at 4100-4300k. If I halogen light (PIAA, etc...) is rated at 4000-5000+k that just means its color is what much more on the blue spectrum (4000+k) or on the yellow spectrum (4000-k).
Even if a halogen light has a high k or a k rating equal to that of a HID blub, the HID bulb will always be brighter because HID's when with high k rating carry a strong l rating (lumens). Lumens is brightness. HID's with there design of arching a strong current through sodium crystal allows them to have a high color rating (k) and also have a strong (bright) l rating (lumens).
Most all halogen bulbs with high k rating have extreamly poor lumen because the brightness is killed by the colored gas. Even the bulbs that have Xenon in then still have a poor lumens rating when they are died colors to get a high k rating.
Old Jun 7, 2002 | 12:50 PM
Apex i ITR's Avatar
What do you think about the 6000k upgrade Rboosted, worth it or not.
Old Jun 7, 2002 | 01:01 PM
if you buy the kit with them for say an extra $200 sure it might be worth it. But to get the kit, then buy extra 6k blubs, forget it.
Old Jun 9, 2002 | 03:30 PM
Black R's Avatar
25 Year Member
.....well on me!
I bought the kit used and got a good deal but... it has d2r bulbs!
Old Jun 10, 2002 | 05:42 AM
Black R's Avatar
25 Year Member
hmmmm... maybe i should get d2s 9006 6000k bulbs to fix my problem? Will they fit? I mean, the ballasts are for d2s/d2r, so all I need to do is get some d2s bulbs? I can go 4300k or 6000k right?
[Modified by Black R, 9:43 AM 6/10/2002]
Old Jun 10, 2002 | 07:31 AM
Cosworth's Avatar
Default Re: Phillips HID kit (Black R)
I got my kit from Trevor on this forum. I believe my bulbs are modified D2S bulbs. I would have to check when I get home.
RDLIN-IT
May 19, 2009 09:00 PM
is3oo
Jan 30, 2002 10:47 PM
gsr camel
Nov 25, 2001 02:27 PM
