Engine Builders. Whats happened to these bearings.
Old Jul 2, 2007 | 05:56 AM
OMG B16's Avatar
Default Engine Builders. Whats happened to these bearings.
My motor was assembled by my dads machine shop, hes not use to honda motors, but does great work. After 1500-2000 miles my block started to knock. Pulled the motor and here is what we found:
Eagle Rods / ACL Bearings
This is a turbo motor, but i figure i'd get some good replies in here. The clearances were within OEM spec, but on the tight side. Any ideas on what the cause is? Were thinking overheated bearings because of the clearances? Any other ideas?
Old Jul 2, 2007 | 06:04 AM
non-VTEC's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (OMG B16)
damn......bearing damage always sucks
you say the specs were within OEM but a little tight? i would say that might be the problem. find out what the exact specs were on the bearing clearances.
what kind of oil were you running? did it get worse over time? or did it just start knocking out of the blue? were you beating on it or just driving it normally?
good luck
Old Jul 2, 2007 | 06:09 AM
.CUBISH.'s Avatar
have you checked the main bearings?
Old Jul 2, 2007 | 06:13 AM
4g hatch's Avatar
with a turbo u should have went on the loose side
Old Jul 2, 2007 | 06:17 AM
TODAwhore's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">have you checked the main bearings?</TD></TR></TABLE>
x2... what was the clearance on the rods and mains?
I'm not a big fan of ACL's ...but thats just me.
Old Jul 2, 2007 | 06:25 AM
OMG B16's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">damn......bearing damage always sucks
good luck</TD></TR></TABLE>
We plastigauged number 4 rod bearing and it was .0010". I was running 15w40 rotella. I was racing , around 5000rpm i felt a suddent loss of power, i let off got it under the light, checked the oil, ect.. Oil was fine, but thats when i heard the knock. I pulled the valvecover to make sure it wasnt in the head. Got the car back to the shop, got it on the lift and could tell it was coming from the block, pulled the oil pan, had some shavings/flakes pulled the rod caps and found this.
We only pulled one main cap and it looked fine.
When i pull the crank and rods to take to the machine shop, i'll check the rest of the mains.
Old Jul 2, 2007 | 07:23 AM
PURPLETERROR aka BIGMATT's Avatar
Clearances seem to be a little on the tight side, detonation, and possibly to thick of an oil also
Old Jul 2, 2007 | 08:20 AM
Big Bang's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (PURPLETERROR aka BIGMATT)
I've seen excesivley rich put enough gas in the oil to do that. What were your a/f ratios?
Old Jul 2, 2007 | 08:28 AM
DonF's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (Big Bang)
That is overheating from not enough clearance and detonation. Ck the side rod cl. also.
Old Jul 2, 2007 | 08:40 AM
.CUBISH.'s Avatar
Default Re: Engine Builders. Whats happened to these bearings. (DonF)
not enough clearnace. and maybe the street tune u had done?
Old Jul 2, 2007 | 07:07 PM
743power's Avatar
ouch, .0010?
thats out of spec and scary tight. This is a b-series?
why the 15w40?
Old Jul 2, 2007 | 08:39 PM
Turbogixxer's Avatar
Default Re: Engine Builders. Whats happened to these bearings. (743power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 743power &raquo;</TD></TR><TR><TD CLASS="quote">ouch, .0010?</TD></TR></TABLE>
It was tighter then that, .0008"
Yes, b-series
TravisBiggie
Engine Machining & Assembly
Jul 23, 2015 07:11 PM
integra3586
19
Aug 25, 2009 09:31 PM
JBLAZE622
Mar 12, 2008 04:53 PM
Cruz2000
Mar 22, 2007 09:17 AM
WhoDoYouThink
21
Mar 27, 2006 03:27 PM
