2000 Civic SI
I been searching and I'm still confused on what to do.
I want to go the Turbo route instead of all motor.
Any suggestions? I'm still looking around but I cna't seem to find much on turbo'n on 2000 Civic si. What should I do, what turbo kit should I get and what should I get after turbo as in maybe get good intercooler, blow off valve, turbo back exhaust, upgrade cams, pistons, fuel injectors...anyhelp? Planning on fixing up the civic this summer. I'll have about 4g's to spend.
Sounds like you haven't done any researching at all. Heres some stuff to get you started:
https://honda-tech.com/zerothread?id=1263795
http://www.beesandgoats.com/bo....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard »</TD></TR><TR><TD CLASS="quote">Sounds like you haven't done any researching at all. Heres some stuff to get you started:
x1,000,000,000
http://www.homemadeturbo.com/
x1,000,000,000
and also https://honda-tech.com/zeroforum/16 jus read a on, and post intelligent questions in that section after researching. You sound like you're in a pretty good situation now. 1) you have $4,000 to spend on a turbo (which is enough for a kit, or you could peice it together w/ money left over) 2)if you're in cali, you're probably going to have to get a edelbrock or greddy turbo kit. Not that you can just run your car however you like everywhere else, but i think cali is suppose to be the most strict.
