NEED HELP!!!... car feels wobbley after replacing axles
alright so i replaced my axles yesterday and after i was done i took it out for a test drive and now when accelerating the car feels really wobbley... theres no noise just feels really woobley and i took everything apart again today and put it back together to make sure everything was done right but still the same thing when i drove it... anybody have the slightest clue what it could be ... it never did that before i did the axles...
when you accel, it wobbles. i had the same problem.
take your axles all the way out, and make sure the cv joints are still good and stiff, and then make sure the spindal part you put in the tranny...is in all the way on, also make sure the half shaft bolts are in tight.
just go over anything that is under the suspention and axle area.
everything is tight and in the right spot...
good luck meng
good luck meng
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elph925 »</TD></TR><TR><TD CLASS="quote">when you accel, it wobbles. i had the same problem.
good luck meng </TD></TR></TABLE>
i redid the drivers side and took everything apart and put everything back together not half-assing anything... but i ran out of time and light to do the passenger side.... maybe will try to do it 2morow if i get someone to help me out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">If you replaced with autozone axles or equivalent remanufactured crap, chances are that your inboard joints are toast.</TD></TR></TABLE>
nah i paid extra to get brand new axles from some shop ...
thanx for the input guys
petr0lb0mb
Transmission & Drivetrain
15
Sep 19, 2018 09:06 PM
VDM_DC2
Suspension & Brakes
11
Oct 28, 2009 12:28 PM
Rocks
Jun 28, 2004 02:25 PM
Log4n
Aug 31, 2003 07:22 AM
-=TWITCH=-
16
Apr 6, 2002 09:22 PM
