will tockico blues for an integra 90-93 (da) fit an ej1?
I've never seen them described as fitting.
For a DA
http://cgi.ebay.com/ebaymotors...ZWDVW
For an Ej
Even in the pictures the shock body and springs look different.
And note the different tokico part #'s
For a DA
For an Ej
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaoss_11 »</TD></TR><TR><TD CLASS="quote">go put them on and see and let us know</TD></TR></TABLE>
i will, guy wants 100 bucks for brand new tockico's all 4 and some brand new generic coilovers that il going to remove and add skunk 2's onto
one hundred bucks is like nothing haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Be prepared for a stiff/bumpy ride with the skunk2's. </TD></TR></TABLE>
I know, people just don't listen.
if only they'd look up the non-linear spring rates for themselves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951BRO »</TD></TR><TR><TD CLASS="quote">its for the ej1 that is getting a k24a1 frank build into it, not exaclty a daily </TD></TR></TABLE>
But if you're going to track it, you'll want something with better springrates.
What shock are you using?
I just don't comprehend getting an expensive swap, and cheaping out on your suspension. Skunk2 does NOT make track worthy suspension. It's a fact.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">THEY DONT FIT!!! (and yes in yelling at you)</TD></TR></TABLE>
Yes, listen to turbociviccoupe here, they don't fit, they are not interchangeable.
I have 2" drop tokico springs on my EJ8 and LOVE the ride. Though that doesn't say much as I'm not big on suspension - they came w/ the car.
they can fit if you use 88-91 crx/civic or 90-93 integra front lower forks
the shock body heights are the same
the only difference is the front shock mount location (the part where the fork clamps around) is smaller on the DA and EF shocks, and bigger on the EG/EK/DC shocks
it'll work
i used EF tokico illuminas on my ej1 with 91 civic front lower forks, worked like a charm
it'll work
SiR Inspired ED7
Jan 17, 2006 04:19 PM
