where can i find a .02 oversized head gasket for the h22
Old Jul 1, 2007 | 06:58 PM
preludefien
Guest
Posts: n/a
Default where can i find a .02 oversized head gasket for the h22
where can i find a .02 oversized head gasket for the h22...
Old Jul 2, 2007 | 12:53 PM
preludefien
Guest
Posts: n/a
Default Re: where can i find a .02 oversized head gasket for the h22 (preludefien)
up
Old Jul 2, 2007 | 04:47 PM
94vtirozguy's Avatar
cometic
Old Jul 5, 2007 | 05:33 PM
Rosko's Avatar
Default Re: (94vtirozguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">cometic</TD></TR></TABLE>
they can make them in just about any size you need. I just ordered an 88mm X .06" thick
Old Jul 5, 2007 | 06:48 PM
preludefien
Guest
Posts: n/a
Default Re: (Rosko)
how much was it
Old Jul 5, 2007 | 06:51 PM
Rosko's Avatar
Default Re: (preludefien)
It was $105 I think, don't remember for sure. I know you can get them cheaper if you buy through a dealer though like Blacktrax.
Old Jul 5, 2007 | 06:52 PM
preludefien
Guest
Posts: n/a
Default Re: (Rosko)
word. thanks bruh. how long did it take for you to get it once you ordered it. and what would you reccomend getting. thick wise.
Old Jul 5, 2007 | 06:54 PM
Rosko's Avatar
heres another alternative...
http://www.horsepowerfreaks.co...skets
I just ordered directly from cometic since mine needed to be a custom size. If you're stock just get the regular .03" one. My setup required a thicker one to keep the compression down.
I ordered it on Monday and it should ship tomorrow because of the holiday.
Old Jul 5, 2007 | 06:55 PM
preludefien
Guest
Posts: n/a
Default Re: (Rosko)
yea im boosting so what would i need or what would you suggest
Old Jul 5, 2007 | 07:00 PM
Rosko's Avatar
I'd just get the .03" and then go with the right pistons to get the desired compression your looking for.
Old Jul 5, 2007 | 07:03 PM
preludefien
Guest
Posts: n/a
Default Re: (Rosko)
yea i have je 9.1 compression with eagle rods. i need some aftermarket head studs and head gasket. the head it all crower.
Old Jul 5, 2007 | 07:05 PM
Rosko's Avatar
that sounds fine.
Old Jul 5, 2007 | 07:09 PM
preludefien
Guest
Posts: n/a
Default Re: (Rosko)
thanks
sivikvtec
Aug 16, 2006 05:10 PM
fafsa
Apr 21, 2005 09:51 AM
skunkd lude
Feb 22, 2004 05:59 PM
EgSick
Dec 21, 2002 12:32 PM
