eg rear disc conversion help please
hey im looking to do a rear disc conversion to my eg hatchback.. what year of integras am i needing to look for to do this swap??? what parts will i need?
what all is needed... do i need a proportioning valve or anything???? whats a list of parts i will need to do this swap? thanks everyone for the help
get the whole trailing arm assembly, brake lines, and the ebrake cables for it. You don't need the prop valve if you're doing a rear disc conversion but it's recommended that u change it out. It's entirely up to u for the prop valve part though.
not changin the prob valve with rear disc conversion aint a must but if you ever have to lock them up its going to be just like pulling the e-brake...so just be prepared to hold tight..
Stiffer pedal feel. 1991 Civic EX sedan Master Cylinder. 15/16 of an inch.
raytownracer
Jan 29, 2009 03:26 PM
98GSR-Turbo
May 16, 2008 02:03 PM
